I was baking, my control panel "froze". Had to trip breaker to turn off oven. Clock wks but all else is dead. New control is pricey, I would like to know if I need to purchase new control part or are there other components that could be wrong? Don't mind spending $$$ if this will correct prob. Thanks.
Originally Posted by: marcianorred I was baking, my control panel "froze". Had to trip breaker to turn off oven. Clock wks but all else is dead. New control is pricey, I would like to know if I need to purchase new control part or are there other components that could be wrong? Don't mind spending $$$ if this will correct prob. Thanks. Marcia, What was on the display when the display froze ? Did you notice any discoloration, wrinkling or de-lamination of the touchpad assembly on the control panel ? When you apply power to the range what occurs, can you reset the clock time, any failure codes, etc. My first inclination is that the touchpad has failed, but I expect a failure code in most cases. I would start at the control panel assembly, before a control. Part number: AP4371193
Thanks to past posts on this site I discovered my "electrical" is still under warranty. I appreciate your help and love love love this service!!!!
Originally Posted by: marcianorred Thanks to past posts on this site I discovered my "electrical" is still under warranty. I appreciate your help and love love love this service!!!! You're welcome, We're glad you appreciate AppliancePartsPros efforts and service. :D :D :D
