Discuss
Broil Element in Oven Will Not Shut Off
 in
Hi, To date I have done the following: Replaced Hi-Limit Switch (located behind display panel) - thinking the old one
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broil Element in Oven Will Not Shut Off
  #1 (permalink)
Old 10-11-2010, 08:11 AM
Junior Member
stebbs is on a distinguished road
Default Broil Element in Oven Will Not Shut Off
Model Number: sve476004w   Brand: Jenn-Air   Age: More than 10 years
  1. Replaced Hi-Limit Switch (located behind display panel) - thinking the old one might be stuck open
  2. Replaced the Electronic Oven Control (EOC) - the display was blank or sometimes extremely dim
  3. Replaced Circuit Board - to eliminate Fault Codes and beeping
  4. Replaced Bottom Element in oven - the old one blew up by litarally popping and flashing
  5. Replaced Top Element in oven - did this since I was in repalcing the bottom, I thought I might as well replace the top
The EOC works great, so does the bottom and top elements, no more fault codes or beeping driving us crazy, so now I am trying to narrow the problem down. Currently to get the top element off I have to turn the power completely off at the breaker panel.
This is frustrating to say the least. Any assistance would be appreciated.
Steve
P.S. I do not have the owners manual and service manual as this unit was with the house when we bought the home. So I am completely relying on Appliance Parts Pros for help. Again thanks for any assistance.
Related Models
Jenn-Air SVE47600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
White Westinghouse SWXG831DS1 White Westinghouse/laundry Center
White Westinghouse SWXG831HQ1 LAUNDRY CENTER
White Westinghouse SWXG831HQ2 LAUNDRY CENTER
White Westinghouse SWXG831HQ4 LAUNDRY CENTER
White Westinghouse SWXG831HS0 LAUNDRY CENTER
White Westinghouse SWXG831HS1 LAUNDRY CENTER
White Westinghouse SWXG831HS2 LAUNDRY CENTER
White Westinghouse SWXG831HS4 LAUNDRY CENTER
Amana SX1021.000 COMMERCIAL MICROWAVES
Amana SX1051.000 COMMERCIAL MICROWAVES
Amana SX19ML REF - SXS/I&W
Amana SX19MW REF - SXS/I&W
Amana SX19NL REF - SXS/I&W
Amana SX19NW REF - SXS/I&W
Amana SX22H REF - SXS/I&W
Amana SX22J REF - SXS/I&W
Amana SX22J Ref - SXS/I&W
Amana SX22MG REF - SXS/I&W
Amana SX22ML REF - SXS/I&W
Amana SX22MW REF - SXS/I&W
  #2 (permalink)
Old 10-11-2010, 10:08 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Steve
Steve,
What was the original problem, and what fail codes did you have ?
When you replaced the circuit board is this the part
Part number: AP4008573
And you're sure you installed the wires correctly ?
Did you also check the wires to the broil element for possible shorted wires to the chassis ?
Hope to hear from you soon,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-11-2010, 07:33 PM
Junior Member
Default
Joe,
Thanks for the response. The original problem was the oven would beep and flash F3 on the EOC. I visited APP, read a few threads, and thought that possibly the Circuit Board might be the issue. Yes, to your question on Part number: AP4008573 as that was exactly what I had ordered and installed after researching my Jenn Air model number sve476004w.
I very carefully wired the board just the way the original was currently installed. I took my time because I barely know anything about electricity/wiring so I know I did it exactly as I saw it on the board.
After putting in the circuit board the EOC continued to get more dim as time went on and finally blanked completely within past two months. This was an inconvenience but we worked around it until the oven finally flashed and popped, startling my wife about three weeks ago. But that was the lower element that had shorted out and we had no problems with the upper element. I just thought when I was ordering the new element for the bottom I would order the top one two as sort of a preventive maintenance issue. Now the upper won't turn off.
The one thing I did not do is your last question: I did not check the element wires for possible shorts to the chassis. I will do that either tomorrow or Wednesday night and report back to you. When I replaced them I simply unscrewed the screws, pulled the elements towards the front of the oven to expose the connectors, popped them off, put the new elements in and replaced the screws. Maybe I didn't get a good connection when putting the connectors back on the elements? Or the wires got shorted out somehow?
Regardless, I will be back in touch in a couple of days.
Thanks again.
Steve
  #4 (permalink)
Old 10-12-2010, 07:06 AM
Senior Expert
Default
Steve
Steve,
The Broil element staying on , was not part of the original complaint, correct ?
Do you still have the original Broil element ?
I reccomend you compare the two elements for exactness, You may have to bend the terminal ends down at a 90 degree angle, so they don't touch the back panel shield, if the element has straight terminals instead of the 90 degree terminals.
Let us know what you find,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven top element works only to broil not bak shutterbug Oven Repair (including Ranges and Cooktops) 1 12-03-2009 02:27 PM
Replacing Broil element on GE Profile Oven tfrer33 Oven Repair (including Ranges and Cooktops) 0 10-07-2009 07:39 PM
19 year old Admiral oven - broil element not working Mysza1975 Oven Repair (including Ranges and Cooktops) 3 06-27-2009 12:41 PM
Thermador oven Broil Element no longer available FredJay Oven Repair (including Ranges and Cooktops) 1 05-12-2009 03:32 PM
Oven upper (broil) element does not work DanT Oven Repair (including Ranges and Cooktops) 1 12-02-2008 01:09 PM
