After pushing "self clean" on the display, the door failed to lock. However the "door locked" message appeared and will not go away. Apparently, the latch assembly is faulty in some way. Neither the Bake nor Broil settings work at all. The word "door" appears in the display when trying to use them. I can cycle through a self clean program but the oven doesn't heat up at all. I even disconnected for an hour through a circuit breaker, but to no avail. Is there a reset button I can activate to clear the display and get back to using the oven again? Thanks for the help!
