| » Whirlpool Oven won't heat up |
Quote:
Can you be more specific on the problem? Gene.
__________________
Professional appliance repair in Orange County, California. |
The oven model number is SF362LXSB0.
The problem is that the oven/broiler does not heat up at all. I checked the gas flow at the valve for the cook top burners, and all is fine there, but nothing comes out when I try to start the oven part. I checked the resistances, but all looks normal there too. |
I bet it's the solenoids on the gas valve check your resistance on it Those valves are crap even tho the top works it would keep the oven from working
http://www.servicematters.com/docs/w...iring_main.htm Check between each solenoid for 216 Ω resistance (Broil terminal to Common, and Bake terminal to Common). NOTE: Always check both solenoids. If one of the solenoids is defective, neither one will operate
__________________
next question are you getting voltage to it? is the electrode sparking? did the safety on the valve accidently get tripped?
__________________
- Last edited by v2k04 : 07-07-2009 at 09:38 AM. |
Part Details - WHIRLPOOL Gas valve/regulator, part number: AP3866825
is the safety the valve in the lower left corner of this picture? |
| Display Modes | |
| Whirlpool Acubake Oven Won't Heat | dbern | Oven Repair (including Ranges and Cooktops) | 1 | 10-05-2008 03:34 PM |
| Whirlpool Dryer won't heat up | jmrobeck | Dryer Repair | 0 | 09-02-2008 12:59 PM |
| whirlpool microwave no heat | samnoypi | Microwave Repair | 0 | 01-12-2008 12:39 PM |
| Whirlpool Oven won't heat stove works fine | tnearman | Oven Repair (including Ranges and Cooktops) | 2 | 10-18-2007 10:13 AM |
| Whirlpool built in single oven doesn't heat | DYLIAM | Oven Repair (including Ranges and Cooktops) | 1 | 08-15-2007 04:54 PM |
