| » Oven not working |
Model Number: MER5875QAF Brand: Maytag Age: 1 - 5 years
Used 2 days ago but yesterday it wouldn’t heat – tried varied temp settings.
Quote:
I'm guessing you mean the bake selection doesn't heat ? Did you look at the element itself , to see if there was any visible damage ? Do you have a multimeter to check for voltage to the element from the control ? Part number: AP4101290 There are several other possibilities, but I would start at the element to determine wether you have a bad element or broken wire or bad control. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Thanks for the compliments,and appreciation. Let us know what you find, Glad to be of help,
__________________
Lon, OK, Once you circuit test the element, if it checks OK(2500 to 3500 ohms). Attach your meter leads to the two wires, that you took off the element and program a bake cycle and see if you get 240 volts across the wires, that will tell us wether we need to go up to the control, and check for damaged wires or terminals.
__________________
Quote:
Thanks. |
Quote:
You're very welcome, We're happy you've got it diagnosed and on the way to repairing and using it. Good Luck,
__________________
Joe - (New element arrived) I removed old element slowly but wires came loose anyway falling behind cabinet. Can I "fish" them out or must cabinet be disassembled? Thanks.
| Display Modes | |
| Magic Chef Double Oven Upper oven not working | scri8e | Oven Repair (including Ranges and Cooktops) | 18 | 12-30-2012 04:50 PM |
| Kenmore Elite oven - PF error, oven not working | virginia3 | Oven Repair (including Ranges and Cooktops) | 1 | 06-24-2009 11:29 AM |
| ge oven not working. Oven door lock problem? | Deano1 | Oven Repair (including Ranges and Cooktops) | 6 | 11-10-2008 01:02 PM |
| Oven not working-Stovetop working | Jame | Oven Repair (including Ranges and Cooktops) | 8 | 10-08-2008 09:08 AM |
| Whirlpool Double Wall Oven - Top Oven Not Working | bigguy | Oven Repair (including Ranges and Cooktops) | 6 | 09-18-2008 09:03 AM |
