Discuss
Old stove
 in
I took a look at the bottom burner with the setting on 400 the igniter glows then when it kicks
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Old stove
  #1 (permalink)
Old 10-17-2008, 02:40 PM
Junior Member
nova10502 is on a distinguished road
Default Old stove
Model Number: 30-4382   Brand: Tappan   Age: 5 - 10 years
with the setting on 400 the igniter glows then when it kicks on the flame is very low
There are times when I here a swish and the flame would get larger
Is this the thermostat causing the problem?
Ads By Google
Related Models
Frigidaire 30-4382-23-01 Tap(v1) / Gas Range
Frigidaire 30-4382-23-02 Tap(v2) / Gas Range
Frigidaire 30-4382-23-03 Tap(v3) / Gas Range
Frigidaire 30-4382-23-04 Tap(v4) / Gas Range
Frigidaire 30-4382-23-05 Tap(v0) / Gas Range
Frigidaire 30-4387-00-01 Tap(v1) / Range
Frigidaire 30-4387-00-02 Tap(v5) / Range
Frigidaire 30-4387-00-03 Tap(v9) / Range
Frigidaire 30-4387-18-01 Tap(v4) / Range
Frigidaire 30-4387-18-02 Tap(v8) / Range
Frigidaire 30-4387-18-03 Tap(v12) / Range
Frigidaire 30-4387-23-01 Tap(v2) / Range
Frigidaire 30-4387-23-02 Tap(v6) / Range
Frigidaire 30-4387-23-03 Tap(v10) / Range
Frigidaire 30-4387-66-01 Tap(v3) / Range
Frigidaire 30-4387-66-02 Tap(v7) / Range
Frigidaire 30-4387-66-03 Tap(v11) / Range
Frigidaire 30-4388-00-01 Tap(v1) / Gas Range
Frigidaire 30-4388-00-02 Tap(v5) / Gas Range
Frigidaire 30-4388-00-03 Tap(v9) / Gas Range
Frigidaire 30-4388-00-04 Tap(v13) / Gas Range
Frigidaire 30-4388-08-01 Tap(v4) / Gas Range
Frigidaire 30-4388-08-02 Tap(v8) / Gas Range
Frigidaire 30-4388-08-03 Tap(v12) / Gas Range
Frigidaire 30-4388-08-04 Tap(v16) / Gas Range
Frigidaire 30-4388-23-01 Tap(v2) / Gas Range
Frigidaire 30-4388-23-02 Tap(v6) / Gas Range
Frigidaire 30-4388-23-03 Tap(v10) / Gas Range
Frigidaire 30-4388-23-04 Tap(v14) / Gas Range
Frigidaire 30-4388-66-01 Tap(v3) / Gas Range
Frigidaire 30-4388-66-02 Tap(v7) / Gas Range
Frigidaire 30-4388-66-03 Tap(v11) / Gas Range
Frigidaire 30-4388-66-04 Tap(v15) / Gas Range
Frigidaire 30-4687-00-01 Tap(v1) / Gas Range
Frigidaire 30-4687-00-02 Tap(v5) / Gas Range
Frigidaire 30-4687-00-03 Tap(v9) / Gas Range
Frigidaire 30-4687-08-01 Tap(v4) / Gas Range
Frigidaire 30-4687-08-02 Tap(v8) / Gas Range
Frigidaire 30-4687-08-03 Tap(v12) / Gas Range
Frigidaire 30-4687-23-01 Tap(v2) / Gas Range
Frigidaire 30-4687-23-02 Tap(v6) / Gas Range
Frigidaire 30-4687-23-03 Tap(v10) / Gas Range
Frigidaire 30-4687-66-01 Tap(v3) / Gas Range
Frigidaire 30-4687-66-02 Tap(v7) / Gas Range
Frigidaire 30-4687-66-03 Tap(v11) / Gas Range
Frigidaire 30-4688-00-01 Tap(v1) / Gas Range
Frigidaire 30-4688-00-02 Tap(v5) / Gas Range
Frigidaire 30-4688-00-03 Tap(v9) / Gas Range
Frigidaire 30-4688-00-04 Tap(v13) / Gas Range
Frigidaire 30-4688-08-01 Tap(v4) / Gas Range
Frigidaire 30-4688-08-02 Tap(v8) / Gas Range
Frigidaire 30-4688-08-03 Tap(v12) / Gas Range
Frigidaire 30-4688-08-04 Tap(v16) / Gas Range
Frigidaire 30-4688-23-01 Tap(v2) / Gas Range
Frigidaire 30-4688-23-02 Tap(v6) / Gas Range
Frigidaire 30-4688-23-03 Tap(v10) / Gas Range
Frigidaire 30-4688-23-04 Tap(v14) / Gas Range
Frigidaire 30-4688-66-01 Tap(v3) / Gas Range
Frigidaire 30-4688-66-02 Tap(v7) / Gas Range
Frigidaire 30-4688-66-03 Tap(v11) / Gas Range
Frigidaire 30-4688-66-04 Tap(v15) / Gas Range
Frigidaire 30-4932-00-01 Tap(v1) / Gas Range
Frigidaire 30-4932-23-01 Tap(v2) / Gas Range
Frigidaire 30-4942-00-01 Tap(v1) / Gas Range
Frigidaire 30-4942-00-02 Tap(v3) / Gas Range
Frigidaire 30-4942-00-03 Tap(v3) / Gas Range
Frigidaire 30-4942-00-04 Tap(v1) / Gas Range
Frigidaire 30-4942-00-06 Tap(v1) / Gas Range
Frigidaire 30-4942-00-07 Tap(v1) / Gas Range
Frigidaire 30-4942-23-01 Tap(v2) / Gas Range
Frigidaire 30-4942-23-02 Tap(v4) / Gas Range
Frigidaire 30-4942-23-03 Tap(v4) / Gas Range
Frigidaire 30-4942-23-04 Tap(v2) / Gas Range
Frigidaire 30-4942-23-05 Tap(v3) / Gas Range
Frigidaire 30-4942-23-06 Tap(v2) / Gas Range
Frigidaire 30-4942-23-07 Tap(v2) / Gas Range
Frigidaire 30-4952-00-01 Tap(v1) / Gas Range
Frigidaire 30-4952-00-02 Tap(v2) / Gas Range
Frigidaire 30-4952-00-03 Tap(v3) / Gas Range
Frigidaire 30-4952-00-04 Tap(v2) / Gas Range
Frigidaire 30-4952-00-05 Tap(v0) / Gas Range
Frigidaire 30-4962-00-01 Tap(v1) / Gas Range
Frigidaire 30-4962-23-01 Tap(v2) / Gas Range
Frigidaire 30-4972-00-01 Tap(v1) / Gas Range
Frigidaire 30-4972-23-01 Tap(v2) / Gas Range
Frigidaire 30-4979-00-01 Tap(v1) / Gas Range
Frigidaire 30-4979-00-02 Tap(v4) / Gas Range
Frigidaire 30-4979-00-03 Tap(v1) / Gas Range
Frigidaire 30-4979-00-04 Tap(v1) / Gas Range
Frigidaire 30-4979-08-01 Tap(v3) / Gas Range
Frigidaire 30-4979-08-02 Tap(v6) / Gas Range
Frigidaire 30-4979-23-01 Tap(v2) / Gas Range
Frigidaire 30-4979-23-02 Tap(v5) / Gas Range
Frigidaire 30-4979-23-03 Tap(v2) / Gas Range
Frigidaire 30-4979-23-04 Tap(v2) / Gas Range
Frigidaire 30-4979-32-03 Tap(v3) / Gas Range
Frigidaire 30-4979-32-04 Tap(v3) / Gas Range
Frigidaire 30-4980-00-01 Tap(v1) / Gas Range
Frigidaire 30-4980-00-02 Tap(v4) / Gas Range
Frigidaire 30-4980-00-03 Tap(v7) / Gas Range
Frigidaire 30-4980-00-04 Tap(v1) / Gas Range
Frigidaire 30-4980-00-05 Tap(v1) / Gas Range
Frigidaire 30-4980-08-01 Tap(v3) / Gas Range
Frigidaire 30-4980-08-05 Tap(v3) / Gas Range
Frigidaire 30-4980-23-01 Tap(v2) / Gas Range
Frigidaire 30-4980-23-02 Tap(v5) / Gas Range
Frigidaire 30-4980-23-03 Tap(v8) / Gas Range
Frigidaire 30-4980-23-04 Tap(v2) / Gas Range
Frigidaire 30-4980-23-05 Tap(v2) / Gas Range
Frigidaire 30-4980-32-02 Tap(v6) / Gas Range
Frigidaire 30-4980-32-03 Tap(v9) / Gas Range
Frigidaire 30-4980-66-04 Tap(v3) / Gas Range
Frigidaire 30-4982-00-01 Tap(v1) / Gas Range
Frigidaire 30-4982-00-02 Tap(v3) / Gas Range
Frigidaire 30-4982-00-03 Tap(v4) / Gas Range
Frigidaire 30-4982-00-04 Tap(v3) / Gas Range
Frigidaire 30-4982-00-05 Tap(v3) / Gas Range
Frigidaire 30-4982-23-01 Tap(v2) / Gas Range
Frigidaire 30-4982-23-02 Tap(v4) / Gas Range
Frigidaire 30-4982-23-03 Tap(v5) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stove top Glenn Mathews Oven Repair (including Ranges and Cooktops) 0 12-29-2009 06:17 PM
stove dmck1nney@netzero.com Oven Repair (including Ranges and Cooktops) 2 09-30-2009 11:50 PM
gas stove kenrays Oven Repair (including Ranges and Cooktops) 5 09-09-2009 04:00 PM
stove whitealligator Oven Repair (including Ranges and Cooktops) 3 12-04-2008 10:00 PM
stove Robin1 Oven Repair (including Ranges and Cooktops) 1 10-17-2007 01:06 PM
