My fridge stopped working; I replaced the timer, then the thermostat, now it works, but I have a frost built-up on the lower back panel in the freezer. I have no clue what to do next. Any help for this gal.
Originally Posted by: girlw/o-a-clue My fridge stopped working; I replaced the timer, then the thermostat, now it works, but I have a frost built-up on the lower back panel in the freezer. I have no clue what to do next. Any help for this gal. Girl W/O, Check for a clogged, frozen defrost drain pan and tube. Check and make sure, the freezer door seal and mullion strip are sealing proper , Check the refrigerator ceiling for ice, frost, or droplets. I'm guessing, you determined the defrost heater was OK ? Start there, and let us know what you found. Good Luck, :) :) :)
Joe, I will check the heater; I'm not sure where it is, but I have a book, so that should make it easier. Sorry about being in the oven--forum. I'm new as you can tell, but trying to learn.
Originally Posted by: girlw/o-a-clue Joe, I will check the heater; I'm not sure where it is, but I have a book, so that should make it easier. Sorry about being in the oven--forum. I'm new as you can tell, but trying to learn. Not a Problem... Your defrost heater is attached to the evaporator, runs across the bottom and about 1/2 way up both sides. Be carefull, The fins on the evaporator are SHARP. :cool: :cool: :cool:
