| » Bottom Oven Panel |
Model Number: JGBP90MEA3BC Brand: GE Age: 5 - 10 years
I want to remove & replace part # AP 2032265....Oven Bottom Panel.
Is a proffessional person needed for this project? Thank you for your help. Ads By Google Related Models |
Quote:
No, a professional should not be needed for this repair. There are two screws in the rear corners of the panel, Loosen, do not remove the screws, and slide the screws towards the front of the oven. Raise the rear of the panel up, carefully, you can use a screwdriver in the slot in the center of the panel if you wish, and slide the panel back until the front flange clears the lip of the cavity bottom(1/2 inch or so). Transfer the two screws and tabs to the new panel, and reinstall reversed of the removal procedure. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Unable to remove bottom panel Kenmore Elite Dryer | addison | Dryer Repair | 17 | 02-07-2012 11:57 AM |
| Oven Bottom Panel | vinmaria | Oven Repair (including Ranges and Cooktops) | 0 | 10-04-2010 08:51 AM |
| Main oven does not heat but the stove top and the bottom oven work | wes2ii | Oven Repair (including Ranges and Cooktops) | 5 | 09-23-2010 01:22 PM |
| Replacing Bottom Oven Panel | NawlinsNative | Oven Repair (including Ranges and Cooktops) | 0 | 04-10-2010 08:31 AM |
| ge profile bottom freezer panel removal | wh07955 | Refrigerator & Freezer Repair | 0 | 07-28-2009 02:20 PM |
