Greetings I broke by front door glass on my stove door, shattered everywhere.. I called GE and they sent me the correct door for my model number.. JGSP23WEY8WW Below is a picture, while this is not the exact picture for that part I believe it is close.. HOW to I do this, do I take the door off it's hinges, lay it down on a soft surface, take the top and bottom screws out. Seperate the from the back, clean out any old glass, intall new glass Is there any extra trick involved? Thankshttps://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00015700/00015760.p03.pdf
Originally Posted by: samiam87 You're on the right track to repair / replace your glass door. There aren't any secrets or special needs to replace it, You should be able to do the repair using the parts diagram you have. Good Luck, :cool: :cool: :cool:
