Discuss
Kenmore drop in oven wont work
 in
Older model kenmore drop in range/oven will not work. When you select bake or broil, it shows on display, starts
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore drop in oven wont work
  #1 (permalink)
Old 10-03-2010, 12:11 PM
Junior Member
o0o_madhatter_o0o is on a distinguished road
Unhappy Kenmore drop in oven wont work
Model Number: 911.4553590   Brand: Kenmore   Age: More than 10 years
Older model kenmore drop in range/oven will not work. When you select bake or broil, it shows on display, starts bake at 100 degrees after you set at 350, or lets you select lo/hi for broil, shortly after, the display just clears like its trying but just shuts off. I figured it may be the bake element so I tried broil but broil doesnt work either. Could it be a limit? Also the top burners are starting to make funny noises when you coook, they work but make weird noises now and then......... PLEASE HELP, its my parents and I wanna help them cause they cant afford a new stove!!
Ads By Google
Related Models
Kenmore 911.6037342  KENMORE 30 IN GAS RANGE
Kenmore 911.6037510  KENMORE 30 INCH GAS RANGE
Kenmore 911.6037520  KENMORE 30 INCH GAS RANGE
Kenmore 911.6037540  KENMORE 30 INCH GAS RANGE
Kenmore 911.6037560  KENMORE 30 INCH GAS RANGE
Kenmore 911.6037610  KENMORE 30 IN. GAS RANGE
Kenmore 911.6037611  KENMORE 30 INCH GAS RANGE
Kenmore 911.6037620  KENMORE 30 IN. GAS RANGE
Kenmore 911.6037640  KENMORE 30 IN. GAS RANGE
Kenmore 911.6037660  KENMORE 30 IN. GAS RANGE
Kenmore 911.6037810  KENMORE 30 INCH GAS RANGE
Kenmore 911.6037812  KENMORE 30 IN. GAS RANGE
Kenmore 911.6037813  KENMORE 30 IN. GAS RANGE
Kenmore 911.6037814  KENMORE 30 IN. GAS RANGE
Kenmore 911.6038110  KENMORE 30 INCH GAS RANGE
Kenmore 911.6047510  KENMORE 30 INCH GAS RANGE
Kenmore 911.6047520  KENMORE 30 INCH GAS RANGE
Kenmore 911.6047540  KENMORE 30 INCH GAS RANGE
Kenmore 911.6047560  KENMORE 30 INCH GAS RANGE
Kenmore 911.6047810  KENMORE 30 IN. GAS RANGE
Kenmore 911.6047811  KENMORE 30 INCH GAS RANGE
Kenmore 911.6047812  KENMORE GAS RANGE
Kenmore 911.6048111  KENMORE 30 IN. GAS RANGE
Kenmore 911.6057510  KENMORE 30 INCH GAS RANGE
Kenmore 911.6057520  KENMORE 30 INCH GAS RANGE
Kenmore 911.6057540  KENMORE 30 INCH GAS RANGE
Kenmore 911.6057560  KENMORE 30 INCH GAS RANGE
Kenmore 911.6128810  Range, Electric/Gas
Kenmore 911.6138810  Range, Electric/Gas
Kenmore 911.6138811  Range, Electric/Gas
Kenmore 911.6138812  Range, Electric/Gas
Kenmore 911.6148810  Range, Electric/Gas
Kenmore 911.6158810  Range, Electric/Gas
Kenmore 911.6158811  Range, Electric/Gas
Kenmore 911.6158812  Range, Electric/Gas
Kenmore 911.6168810  Range, Electric/Gas
Kenmore 911.61771790  Range, Electric/Gas
Kenmore 911.61775790  Range, Electric/Gas
Kenmore 911.6178810  Range, Electric/Gas
Kenmore 911.6178811  Range, Electric/Gas
Kenmore 911.6178812  Range, Electric/Gas
Kenmore 911.62771790  Range, Electric/Gas
Kenmore 911.6288810  Range, Electric/Gas
Kenmore 911.6298811  Range, Electric/Gas
Kenmore 911.6348810  Range, Electric/Gas
Kenmore 911.7129180  GAS RANGE
Kenmore 911.7129181  GAS RANGE
Kenmore 911.7129182  GAS RANGE
Kenmore 911.7139180  GAS RANGE
Kenmore 911.7139181  GAS RANGE
Kenmore 911.7139182  GAS RANGE
Kenmore 911.7148810  Range, Electric/Gas
Kenmore 911.7158810  Range, Electric/Gas
Kenmore 911.7158811  Range, Electric/Gas
Kenmore 911.7158812  Range, Electric/Gas
Kenmore 911.7168810  Range, Electric/Gas
Kenmore 911.7178810  Range, Electric/Gas
Kenmore 911.7178811  Range, Electric/Gas
Kenmore 911.7178812  GAS RANGE
Kenmore 911.7179180  GAS RANGE
Kenmore 911.7179181  GAS RANGE
Kenmore 911.7179182  GAS RANGE
Kenmore 911.7199180  GAS RANGE
Kenmore 911.7199181  GAS RANGE
Kenmore 911.7199182  GAS RANGE
Kenmore 911.7218811  Range, Electric/Gas
Kenmore 911.7218812  Range, Electric/Gas
Kenmore 911.7279180  GAS RANGE
Kenmore 911.7279181  GAS RANGE
Kenmore 911.7279182  GAS RANGE
Kenmore 911.7299180  GAS RANGE
Kenmore 911.7299181  GAS RANGE
Kenmore 911.7299182  GAS RANGE
Kenmore 911.7313190  GAS RANGE
Kenmore 911.7340190  30" GAS RANGE
Kenmore 911.7340191  GAS RANGE
Kenmore 911.7340192  GAS RANGE
Kenmore 911.7359180  GAS RANGE
Kenmore 911.7359181  GAS RANGE
Kenmore 911.7360190  GAS RANGE
Kenmore 911.7360191  GAS RANGE
Kenmore 911.7360890  GAS RANGE
Kenmore 911.7360891  GAS RANGE
Kenmore 911.7360990  GAS RANGE
Kenmore 911.7360991  GAS RANGE
Kenmore 911.8007111  ROTISSERIE KIT
Kenmore 911.8007410  OPTIONAL ROTISSERIE KIT
Kenmore 911.8067110  PORCELAIN PAN & CHROME RING KIT
Kenmore 911.8067111  OPTIONAL PORCELAIN PAN AND CHROME RING KIT 8067111
Kenmore 911.8067120  PORCELAIN PAN & CHROME RING KIT
Kenmore 911.8067121  OPTIONAL PORCELAIN PAN AND CHROME RING KIT 8067121
Kenmore 911.8067410  OPTIONAL ALUMINUM BROILER PAN & GRID KIT
Kenmore 911.8067430  OPTIONAL PORCELAIN BROILER PAN & GRID KIT
Kenmore 911.9107810  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9107910  KENMORE 30 IN. ELECTRIC RANGE
Kenmore 911.9107911  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9107912  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9108010  KENMORE 30 IN. ELECTRIC RANGE
Kenmore 911.9108011  KENMORE 30 IN. ELECTRIC RANGE
Kenmore 911.9108110  KENMORE ELECTRIC RANGE
Kenmore 911.9108111  KENMORE ELECTRIC RANGE
Kenmore 911.9108112  KENMORE 30 IN ELECTRIC RANGE
Kenmore 911.9108113  KENMORE 30 IN. ELECTRIC RANGE
Kenmore 911.9108610  KENMORE ELECTRIC RANGE
Kenmore 911.9108810  ELECTRIC RANGE
Kenmore 911.9112190  ELECTRIC RANGE
Kenmore 911.9112590  ELECTRIC RANGE
Kenmore 911.9117510  KENMORE 30 IN ELECTRIC RANGE
Kenmore 911.91181890  30" ELECTRIC RANGE
Kenmore 911.9118710  KENMORE ELECTRIC RANGE
Kenmore 911.9118810  ELECTRIC RANGE
Kenmore 911.91188890  30" ELECTRIC RANGE
Kenmore 911.9127510  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9127610  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9127611  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9127612  KENMORE ELECTRIC RANGE
Kenmore 911.9127810  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9128010  KENMORE 30 IN. ELECTRIC RANGE
Kenmore 911.9128011  KENMORE 30 INCH ELECTRIC RANGE
Kenmore 911.9137510  KENMORE 30 INCH ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
icemaker wont drop ice Karlasmommy Refrigerator & Freezer Repair 7 08-09-2011 02:00 PM
Kenmore Gas Range bake/broiler wont work stillinkent Oven Repair (including Ranges and Cooktops) 1 11-18-2009 04:48 PM
Drop-In Range Display Wacky, Oven & Broiler Don't Work mydogsmom Oven Repair (including Ranges and Cooktops) 3 06-05-2009 11:28 PM
Kenmore gas owen bake wont work Ramax Oven Repair (including Ranges and Cooktops) 1 02-12-2008 10:28 PM
kenmore wont work gatemindr1 Dishwasher Repair 0 01-26-2008 06:16 AM
