Discuss
Can not get Oven to light, pilot ok
 in
I can not get the oven burner to light. The stove top burners work. The pilot lights low at first,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Can not get Oven to light, pilot ok
  #1 (permalink)
Old 10-02-2010, 12:37 PM
Junior Member
Barbarian is on a distinguished road
Default Can not get Oven to light, pilot ok
Model Number: CYL1610ADW   Brand: Maytag   Age: 1 - 5 years
I can not get the oven burner to light. The stove top burners work. The pilot lights low at first, then grows in size when the oven temperature is set above "Pilot."
There are two vales inline with the burner. The top valve, "thermostat valve" is on with the cook top controls and has the temperature knob attached to it. The second valve, is the "oven valve", it is located in the oven compartment connects directly to the burner and it has a thermal sensor under the pilot flame. The thermostat valve supplies gas to the oven valve. I removed the gas line to the oven valve and confirmed gas is flowing to the oven valve. That is the supply line to the oven valve seems clear. I replaced the oven valve with a new one. I still have the same problem. Pilot lights, heats the sensor, gas never flow to the oven burner.
  • Did I get a defective oven valve?
  • Should I replace it again?
  • Is there something tricky about mounting the oven sensor near the pilot? I tried heating the sensor with a butane lighter while the pilot was burning. So I know the sensor got good and hot.
  • Is there a way to test the oven valve with it removed from the oven?
This is getting really frustrating because I can not bake cookies or toast bread in my trailer anymore.
Ads By Google
Related Models
Hardwick D-150 Range - F/s Std Ele
Hardwick D-170 Range - F/s Std Ele
Hardwick D-445 Surface Unit - Ele
Hardwick D-456 Surface Unit - Ele
Hardwick D-950 Range - F/s Std Ele
Amana D1150.000 Mwave - Family Size (60 Hz)
Jenn-Air D120 Range - D/i Std Ddraft Ele
Amana D1200 Mwave - Family Size (60 Hz)
Amana D1250 Mwave - Family Size (60 Hz)
Amana D1270.000 Mwave - Family Size (60 Hz)
Amana D1280.000 Mwave - Family Size (60 Hz)
Amana D13 Freezer - Vertical
Amana D13A Freezer - Vertical
Amana D13C Freezer - Vertical
Amana D13F Freezer - Vertical
Frigidaire D13FA0 Frg(v2) / Refrigerator
Frigidaire D13FF0 Frg(v4) / Refrigerator
Frigidaire D13FH0 Frg(v3) / Refrigerator
Frigidaire D13FL0 Frg(v5) / Refrigerator
Frigidaire D13FW0 Frg(v1) / Refrigerator
Amana D13L Freezer - Vertical
Frigidaire D13MA8 Frg(v2) / Refrigerator
Frigidaire D13MF8 Frg(v4) / Refrigerator
Frigidaire D13MH8 Frg(v3) / Refrigerator
Frigidaire D13ML7 Frg(v1) / Refrigerator
Frigidaire D13ML8 Frg(v5) / Refrigerator
Frigidaire D13MW7 Frg(v2) / Refrigerator
Frigidaire D13MW8 Frg(v1) / Refrigerator
Jenn-Air D140 Range - S/i Std Ddraft Ele
Jenn-Air D140-C Range - S/i Std Ddraft Ele
Jenn-Air D146 Range - S/c D/i Ddraft Ele
Jenn-Air D146-C Range - S/c D/i Ddraft Ele
Jenn-Air D146B Range - S/c D/i Ddraft Ele
Jenn-Air D146B-C Range - S/c D/i Ddraft Ele
Jenn-Air D146W Range - S/c D/i Ddraft Ele
Jenn-Air D156 Range - S/c D/i Ele
Jenn-Air D156-C Range - S/c D/i Ele
Jenn-Air D156B Range - S/c D/i Ele
Jenn-Air D156B-C Range - S/c D/i Ele
Jenn-Air D156W Range - S/c D/i Ele
Amana D16 Freezer - Vertical
Amana D16C Freezer - Vertical
Amana D16L Freezer - Vertical
Amana D18 Freezer - Vertical
Amana D18B Freezer - Vertical
Amana D18E Freezer - Vertical
Amana D20 Freezer - Vertical
Whirlpool D200
Amana D23 Freezer - Vertical
Amana D23A Freezer - Vertical
Amana D23B Freezer - Vertical
Amana D25 Freezer - Vertical
Whirlpool D25A0
Whirlpool D25A1
Whirlpool D25A2
Whirlpool D25B0
Whirlpool D300
Frigidaire D3000 Gib(v1) / Food Disposer
Frigidaire D3001 Gib(v2) / Food Disposer
Whirlpool D30A0
Whirlpool D30A1
Whirlpool D30A2
Whirlpool D30A3
Whirlpool D30B0
Maytag D31100PAAL Range - F/s Std Gas
Maytag D31100PATL Range - F/s Std Gas
Maytag D31100PAWL Range - F/s Std Gas
Maytag D31100SAAL Range - F/s Std Gas
Maytag D31100SAWL Range - F/s Std Gas
International D31103SAAL Range - F/s Std Gas
International D31103SAWL Range - F/s Std Gas
International D3110PRALT Range - F/s Std Gas
International D3110PRWLT Range - F/s Std Gas
Maytag D31111WAAL Range - F/s Std Gas
Maytag D31111WAWL Range - F/s Std Gas
Maytag D31113XAAL Range - F/s Std Gas
Maytag D31113XATL Range - F/s Std Gas
Maytag D31113XAWL Range - F/s Std Gas
International D3120SRALT Range - F/s Std Gas
International D3120SRWLT Range - F/s Std Gas
International D3121WTALT Range - F/s Std Gas
International D3121WTWLT Range - F/s Std Gas
International D3121XTALT Range - F/s Std Gas
International D3121XTWLT Range - F/s Std Gas
International D3167XRALT Range - F/s Std Gas
International D3167XRWLT Range - F/s Std Gas
International D3167XUALT Range - F/s Std Gas
International D3167XUWLT Range - F/s Std Gas
International D3167XVALT Range - F/s Std Gas
International D3167XVWLT Range - F/s Std Gas
Maytag D31FA-7-D Range - F/s Std Gas
Maytag D31FK-7-D Range - F/s Std Gas
Maytag D31FN-7-D Range - F/s Std Gas
Maytag D31FY-7-D Range - F/s Std Gas
Amana D396151 Misc / Accessory
Whirlpool D400
Whirlpool D401
Whirlpool D40A0
Whirlpool D40A1
Whirlpool D40A2
Whirlpool D40A3
Whirlpool D40B0
Whirlpool D500
Frigidaire D5000 Gib(v3) / Food Disposer
Whirlpool D50A0
Whirlpool D50A1
Whirlpool D50A2
Whirlpool D50B0
Whirlpool D5257X2
Whirlpool D5257^2
Frigidaire D5500 Gib(v1) / Food Disposer
Frigidaire D5501 Gib(v2) / Food Disposer
Hoover D6047 Undercounter Dishwasher
Hoover D6047-2
Hoover D6047-5
Hoover D6047-6
Whirlpool D6757X0
Whirlpool D6757X1
Whirlpool D6757^0
Whirlpool D6757^1
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cant light pilot on oven Theron Mills Oven Repair (including Ranges and Cooktops) 1 10-07-2009 02:27 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
oven ignitor not clicking, but pilot will light manually and then the oven will work rosscol Oven Repair (including Ranges and Cooktops) 0 09-10-2008 05:37 PM
oven ignitor not clicking, but pilot will light manually and oven work then rosscol Oven Repair (including Ranges and Cooktops) 1 09-03-2008 04:30 PM
oven won't light-pilot is off cherylk Oven Repair (including Ranges and Cooktops) 0 01-01-2008 08:10 AM
