Wanted to get some quick advice on her before I do anything stupid!!..I am getting the error code F1 and the incessant beeping only when the oven is NOT IN USE...I can get the beeping to stop by turning the oven on bake or on the clean cycle...Unfortunately the beeping starts 15 seconds after I stop using the oven.It is getting old having to turn the oven on/off at the circuit breaker anytime I want to use it... :( Is there a way to override the beeping......can't afford new range at this time.
