Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Gas Range Oven will not heat (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/12967-gas-range-oven-will-not-heat.html)
wetheridge 10-14-2008 08:44 AM
I have a GE Profile 30" gas range model JGBP86BEB1BB my oven will not heat but the broiler will. I do not get any error messages on the front panel. I am very mechanical and want to fix this problem myself. I am looking at the igniter as the possible problem. Does anyone have other suggestions? I am also looking for a repair diagram
Wayne
libertyappl 10-14-2008 08:55 AM
The model number posted shows a gas top and an electric oven.
Here's the breakdown Model JGBP86BEB1BB
If this is the correct model number check the element and wires to it. There is also a sensor (part #238 on page 4) you may want to check.
Nat
