angie1754
#1 Posted : Thursday, September 30, 2010 10:45:23 AM(UTC)
angie1754
Dear Tech,
No smell of gas inside oven, stove top working. Whern turning on R selector to qven and then L Temperature oven does not fire up.
Ignitor was changed successfully 4 months ago and oven worked therafter.
Diagram is on this web site.
Thank you
Frank
Joe / APP Team
#2 Posted : Thursday, September 30, 2010 1:15:59 PM(UTC)
Joe / APP Team
Originally Posted by: angie1754 Go to Quoted Post
Dear Tech,
Thank you
Frank
Does the broiler work and heat ?
Are you sure the new igniter is not the problem ? (loose connection, cracked broken igniter, etc.)
Do you have a VOM multimeter so you can check for voltage to the bake igniter from the thermostat ?
This is where we need to start , so we know what direction to take.
angie1754
#3 Posted : Saturday, October 2, 2010 10:20:34 PM(UTC)
angie1754
Joe M. Thank you
NO the broiler does not work and light/ heat up.
Remember I stated that I don`t think there is anything wrong with the ignitor because there is no smell of gas entering the area of the ignitor as was the case when I needed to change the ignitor 5 months ago.
Frank
Joe / APP Team
#4 Posted : Monday, October 4, 2010 6:39:09 AM(UTC)
Joe / APP Team
Joe M. Thank you
Frank
Frank,
Check and make sure, your Clock is Not set in a Self Clean or Timed Bake,
setting, by mistake, It has to be set in a Manual mode for the oven to operate,
If that checks OK.
You will need to check for 120 VAC across the 2 wires to the igniter(s), from
the thermostat / control with the oven in a bake and broil settings, to
determine if you have a broken wire or inoperative control.
Good Luck,
Frank Barry (Dryer Repair)
by Frank Barry 4/5/2016 9:35:25 AM(UTC)
Franklin Chef refrig/freezer stopped working (Refrigerator & Freezer Repair)
by Baseball Dad 6/25/2012 11:15:01 AM(UTC)
franklin000 (Microwave Repair)
by franklin000 6/5/2012 6:53:08 PM(UTC)
Frank (Oven Repair (including Ranges and Cooktops))
by angie1754 9/29/2010 12:35:19 PM(UTC)
by FBRTKO 11/11/2009 3:02:23 PM(UTC)
jerfrank (Dryer Repair)
by jerfrank 6/26/2009 8:49:31 AM(UTC)
by bigbluetrk17 3/25/2009 8:48:34 AM(UTC)
frank (Refrigerator & Freezer Repair)
by frose 2/24/2008 6:14:15 PM(UTC)
Frank (Washer Repair)
by fvas 8/29/2007 9:01:01 AM(UTC)
