| » Amana electric range (oven) wont heat up |
Model Number: AES1350BAW Brand: Amana Age: 1 - 5 years
my oven will not get hot. i just replaced the
bake element part no. 74010883. i was wondering what else could be wrong?.. when i turn the oven on i get no error codes or anything it just starts off at 100 degrees for the preheat but the temp never goes up and the lower bake element never gets hot .(even the new one) any help would be greatly appreciated Thanks Paul also i have made sure that it is not on bake delay i am wondering if it is the oven sensor.... when i went to check continuity it read nothing and when i checked OHMs it also read nothing. Ads By Google Related Models Last edited by flukekiller : 09-30-2010 at 07:40 AM. Reason: added more info |
Replacement parts for AMANA AES1350BAW Range - S/c S/i Ele | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/maytag...s/16026294.pdf And a manual http://www.servicematters.com/maytag...s/16026299.pdf Here is a good site with info on the sensor etc. http://www.applianceaid.com/elecrange.html i just replaced thebake element part no. 74010883. i was wondering what else could be wrong?.. Did you check the element before replacing it or did you just replace it as the most likely cause? You did not say if the stove top elements are working OK. If not you probably have a power problem. when i turn the oven on i get no error codes or anything it just starts off at 100 degrees for the preheat but the temp never goes up and the lower bake element never gets hot Does the broil element work? i am wondering if it is the oven sensor.... when i went to check continuity it read nothing and when i checked OHMs it also read nothing. By nothing do you mean 0 ohms or infinite ohms? Also what meter scale were you using? You should use 2,000 ohms or higher to check it. The unit does have a hi-limit thermostat perhaps this is toast. Unplug the unit and one side of the hi-limit thermostat and check it. Should be 0 ohms.
__________________
the bake element was reading 7 OHMS so that is why i replaced that
and the temp sensor was reading 0 OHMS thats why i think that it is this the high limit is reading 0 OHMS but i believe that this is supposed to be at 0 and i was using the 2,000 scale thanks for the help i will let you know how it goes paul |
On the below readings did you remove the wires from at least one side of the device you were measuring. This ensures that you do not read an alternate/parallel circuit path
the bake element was reading 7 OHMS so that is why i replaced that This is weird as it is low but I have never seen an element drop this low. It is basically just a ni-chrome wire in ceramic so it is very hard for it to short out partially. and the temp sensor was reading 0 OHMS thats why i think that it is this Yes, this does look bad the high limit is reading 0 OHMS but i believe that this is supposed to be at 0 and i was using the 2,000 scale When checking for 0 ohms it is alwauys a good idea to use your most sensitive scale.
__________________
yes i removed one wire or the entire unit when testing...
i do not know much about electric ranges but i thought that it was odd for the bake element to read 7 from all the info i have read online. that is why i replaced this first.. i know its uncommon but it could happen ,which i believe happened here, is that the bake element and the temp sensor both went at the same time. i am waiting for the temp sensor to come in today.. unfortunately where i live , no stores ever have anything instock and need to order the items. Thanks for all the help paul |
| Display Modes | |
| amana oven wont heat | russ100 | Oven Repair (including Ranges and Cooktops) | 7 | 01-06-2011 04:58 AM |
| Amana Electric oven won't heat | m218perez | Oven Repair (including Ranges and Cooktops) | 10 | 12-12-2009 12:17 PM |
| kenmore electric range oven wont shut off | nrmrz | Oven Repair (including Ranges and Cooktops) | 0 | 07-23-2009 02:45 PM |
| Electric Oven wont heat | cricket1214 | Oven Repair (including Ranges and Cooktops) | 2 | 07-09-2009 12:30 PM |
| Amana/Maytag Electric oven won't heat above 250 | quickmom | Oven Repair (including Ranges and Cooktops) | 1 | 06-11-2009 02:53 PM |
