Hello,
I turn on the oven using the LED panel....select a temperature....it starts to heat up and before it reaches the desired temperature, it shuts off. Same thing with the broiler.....cowl rod gets red hot and after a few minutes, it shuts off. Would a faulty thermostat be the cause? Or, is the problem with the LED control panel? Thanks for any advice. :confused:
