What does F4 error message mean on this Amana model with serial# 9809293490?
Originally Posted by: Kharden What does F4 error message mean on this Amana model with serial# 9809293490? Kharden, The F4 failure code would indicate a shorted oven temperature sensor. Part number: AP4282440
You should check the resistance of the sensor, ( 1100 ohms or less at room temp) and wiring to the control connection. If that checks correct, you'd need to replace the control. Part number: AP4040613
Good Luck, :cool: :cool: :cool:
