Tried cleaning my oven. The latch made a funny noise and I cannot open the lower over door. Tried turning the circuit breaker on and off and it still doesn't work. The oven still works, just can't open the door
I had the same issue with my Thermadore PDR304 oven. I turned the breaker off for about an hour and let the oven cool completely down and then put the breaker back on and the door unlocked itself. I think the oven still thinks it is in cleaning mod and too hot to let you open it and by turning the breaker off and cooling down I think it resets the sensor....that is only a guess. Make sure you take the grills out before cleaning the oven! That worked for me.
