Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Range Problem (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/129045-range-problem.html)
cw0k 09-28-2010 03:29 PM
Range Problem
My Amana is an electric, glass top. When it was under warranty, the oven and burners started to shut off, the range lost power. But if I turned on the right, back burner, the range would work again.
The repairman told me that particular burner controlled the rest of the range. It didn't take him but a few minutes and one part to fix it. Well, it's doing it again. What part do I need to fix it? I also remember, he lifted off the part above the knobs to replace the part, behind the top, back, right burner.
Any help you give, would be great!
Serial # is 9906203740
