theroundrobin
#1 Posted : Tuesday, September 28, 2010 10:32:38 AM(UTC)
theroundrobin
Is this an easy item for a DIY job? Any pictures or precautions anyone would have to help on this? Thanks in advance.
Joe / APP Team
#2 Posted : Tuesday, September 28, 2010 10:58:31 AM(UTC)
Joe / APP Team
Roundrobin,
It usually is a pretty easy repair, just basic handtools .
But first,
Why are you replacing the element, is it visibly damaged or broken ?
The repair itself is relatively easy :
Turn power off the range, or unplug power cord.
With oven door open or removed(removal is best) remove screws holding element assembly to oven wall.
Carefully slide element assembly out of cavity wall opening and disconnect wires from element terminals.
Reverse procedure to complete repair.
I believe this is the part you are needing
Part number: AP4268250
Good Luck,
theroundrobin
#3 Posted : Tuesday, September 28, 2010 11:18:30 AM(UTC)
theroundrobin
Originally Posted by: Joe / APP Team Go to Quoted Post
Roundrobin,
But first,
Good Luck,
Thanks, Joe. When turned on to preheat, the element showed one particular hot spot and in a few seconds started arcing. Turned off and assumed element would need to be replaced...correct?
Joe / APP Team
#4 Posted : Tuesday, September 28, 2010 11:36:21 AM(UTC)
Joe / APP Team
Roundrobin,
Very Good,
Yes , your element is about gone.
Didn't want you replacing a part you may not need.
Just Remember to turn off the power, you don't want to short anything out,
Parts are getting scarece for older units.
:cool: :cool: :cool:
theroundrobin
#5 Posted : Saturday, October 2, 2010 1:23:04 PM(UTC)
theroundrobin
Thanks, Joe. I got one and will remember to cut off the power first.
Joe / APP Team
#6 Posted : Monday, October 4, 2010 6:16:44 AM(UTC)
Joe / APP Team
Roundrobin,
Great,
Yes, Please Remember to Shut OFF the Power,
We don't want you getting hurt.
Good Luck,
replacing bake element (Oven Repair (including Ranges and Cooktops))
by gazagar 5/18/2012 8:08:12 AM(UTC)
by TASinger 10/15/2010 7:16:48 AM(UTC)
Replacing Bake Element (Oven Repair (including Ranges and Cooktops))
by hpotts 9/27/2010 5:44:41 PM(UTC)
by staceymoore01 10/8/2007 3:24:41 PM(UTC)
