I have a Dacor double oven that quit working after a bad storm with heavy lightning that also effected other items in our house such as our Lutron dimmer switches. This is the second time this has happened. First time I brought a repair company in and it cost me $320.00. They replaced the "reset high limit switch" and it worked find until we got hit again. I ordered and replaced the same switch. The display panel still will not light up. The oven lights due work now. The oven will not operate at all. When I push the "cancel / secure" touch pad the display reads "99" permanently. The only way I can get "99" to clear is to shut off the breaker. If I push "cancel / secure" touch pad "99" appears again. Can anyone help me out? Could I have hooked the switch up backwards or do I have something else wrong too? Thanks for your help in advance!
