I have a Magic Chef Range Model 68HK-6TXW and have a problem with keeping the oven on. It will turn on but will only run for about 15 sec. and shut off. I believe the problem must be in the clock control/relay module. I have check the heating elements and they are ok. The module has a cn:760P178-60 & sn:00012455 on it. I have tried to find this part but it looks like it is obsolete. Is there a replacement part no.? Cost? The rest of the stove works fine. Thanks.
