Discuss
Lynn Borum
 in
can you help me I am trying to find out how and where to light the oven on a gas
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Lynn Borum
  #1 (permalink)
Old 10-09-2008, 11:57 AM
Lynn Borum Lynn Borum is offline
Junior Member
Lynn Borum is on a distinguished road
Default Lynn Borum
Model Number: HAV668-19G   Brand: Tappan   Age: More than 10 years
can you help me
I am trying to find out how and where to light the oven on a gas cook stove
all of the burners work fine on top
i just can't seem to make heads or tails out of the lighting instruction inside the door inside the oven
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-09-2008, 12:00 PM
Junior Member
Question
trying to find out how to light gas stove
  #3 (permalink)
Old 10-09-2008, 12:01 PM
v2k04 v2k04 is online now
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
next to the main burner is a pilot assy. unless it has a glowcoil
  #4 (permalink)
Junior Member
Default
Quote:
  #5 (permalink)
Old 10-09-2008, 12:07 PM
Senior Expert
APP Volunteer
Default
the burner and pilot are easier to get to by removing bottom plate in oven there are usually two screws on either side then the plate lifts up and out then under that is usually a spreader plate that when the flame hits it causing the flame off the burner to get wider remove the plate usually its held on buy a 3/8 nut in the center then you can see right on top of burner and pilot assy
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lynn Lynn Oven Repair (including Ranges and Cooktops) 1 11-05-2007 06:26 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
