| » KitchenAid kesc308 display panel went out |
Model Number: KESC308LSS0 Brand: Kitchen Aid Age: 5 - 10 years
I have a KitchenAid KESC308L Slid in Electric Range. It's around 6 years old. Today, the electronic control/display panel went out. No LED's light; however, when any buttons are pressed on the panel, it responds with a beep -- which lets me know that it recognizes that buttons are being pressed. Also, when I press the Oven Light button, the oven light does, in fact, toggle on and off in response to the control panel. Also, the mechanical (rotary) knobs that control the cooktop burners are working -- i.e., the burners turn on and heat up correctly in response to the control knobs. The problem is that the LED display info is all dark; so there's no way to set or control the oven. Has anyone seen a problem like this before with a KitchenAid Range? Any idea what went wrong, or how to fix this?
I also have a KitchenAid KESC308L Slid in Electric Range. My control panel display would sporadically stop working, now it never lights up. Everything responds and works properly, but nothing lights up. I have seen this post on here, but no solutions or suggestions have been posted. Anyone have any ideas?
Quote:
I suspect that the solder used at the factory was RoHS complaint and did not contain lead. The lead gives the joint elasticity and makes for a better connection. This takes a steady hand and the right tools. Not something a first-timer should try. But, I performed this repair last night and the intermittent problem has gone away. I used to be able to cause the display to cut in and out by manipulating the ribbon cable and now I cannot. |
[quote=The problem may be a cold solder joint on the male 13-pin AMP connector on the display board.[/QUOTE]
I had the same issue with intermittent control panel LED operation. If I bumped the surface of the panel lightly with my fist, the control lights would come back on for a time, but go dark again eventually. Removed the electronic oven control board as suggested above, and when examining the underside where the 13-pin connector solder joints are, I could just make out a hairline crack at the base of the leftmost pin. In fact, I plugged the range back in and very gingerly wiggled the connector back and forth slightly and could see the LEDs working. I re-soldered just that one joint (unplugging the range again first), re-assembled, and all LEDs work like new--thanks for the repair advice! |
| Display Modes | |
| kitchenaid superba slide in,no display when plugged in | twospot | Oven Repair (including Ranges and Cooktops) | 2 | 02-21-2011 08:40 PM |
| Display out, Panel still works | cincinnatithompson | Oven Repair (including Ranges and Cooktops) | 0 | 06-12-2010 11:06 AM |
| Kitchenaid KGRT607HWH6 - no control panel display | ed111 | Oven Repair (including Ranges and Cooktops) | 0 | 12-19-2009 09:58 PM |
| kitchenaid range top display intermitant | chris cole | Oven Repair (including Ranges and Cooktops) | 1 | 12-03-2009 06:15 AM |
| Kitchenaid Gas Stove Ctrl Panel works but no Display | Karpentor | Oven Repair (including Ranges and Cooktops) | 1 | 08-22-2009 05:37 AM |
