| » whirlpool oven code F3 63 oven won't turn on |
Model Number: GS563LXSS Brand: Whirlpool Age: 1 - 5 years
My whirlpool oven won't turn on, broiler also, everything else works, it has a code F363, I can hear the lock or solinoids click on then off, but no heet. I replaced the temp probe, that did not correct the problem? is this a controller issue?
Quote:
I think, you mean you have an F3-E3 code, there is no F363 code for your unit(unless you've got a bad ERC). If you have replaced the oven temperature sensor, and checked the wiring and connections from the sensor to the ERC. Then, YES the ERC is most likely the problem. Part number: AP4339950 ![]()
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
F3-E3 Clean temperature out of range (too high)
- BAKE elements does not turn off Here is the tech sheet with all the codes for your model and diagnostic information.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
Quote:
According to the earlier post by Joe from App team, he says it is the control panel. One of the issues is that my stove seems to go into control lock on its own at random times. I have seen it happen when I loose power (which is expected). However sometimes it beeps and locks itself without any reason and power has not been interrupted. Trying to nail this issue down has been a very frustrating and expensive way to troubleshoot. |
Quote:
It doesn't seem like you have the same issue, not with the additional information. It sounds more involved. But if you follow the instructions on the tech sheet, AJ included with the previous post you should bave it figired out shortly. Just read and closely follow the instructions, and you'll do fine.
__________________
| Display Modes | |
| Whirlpool Oven does not turn off | bgnfan | Oven Repair (including Ranges and Cooktops) | 6 | 08-17-2010 08:28 AM |
| whirlpool oven wont turn on | sgrafins | Oven Repair (including Ranges and Cooktops) | 0 | 07-04-2010 02:54 PM |
| whirlpool oven can not turn off | whirpooloven | Oven Repair (including Ranges and Cooktops) | 2 | 10-29-2009 07:13 AM |
| Whirlpool oven won't turn off | Pat LaPorte | Oven Repair (including Ranges and Cooktops) | 5 | 06-25-2009 07:56 PM |
| Whirlpool oven won't turn off | curt w | Oven Repair (including Ranges and Cooktops) | 2 | 10-20-2008 06:50 PM |
