Having an issue with my electric wall oven. Jenn Air ww30430w. Top oven bake element will not turn on. Had a prior issue where the female wire harness on the orange wire melted away. Replace harness and bake element. Bake burner replace approx 2 months ago. Recently had the same issue. Insulation around female wire harness on orange wire gone. Replace female on orange again. Still does not work. Main board 2 - 3 yrs. Is it the high limit switch that is faulty or am I looking at needing to buy a new board?
THIS FORUM IS DEAD!!!!!!! |
