when i turn on my oven i smell gas there seems to be a light coming from the broiler works fine. It never reaches the correct heating tempaerture
Thanks Gene that worked.[ quote=Gene;275503]Most likely the problem is a bad (weak) bake igniter (#218 on the diagram). - The igniter Part number: AP2020569
You are welcome. I'm glad you were able to fix it.
