My Amana oven turns itself off after it has been on for 5-10 mins and the control panel then goes blank. After 20-30 minutes, when it has cooled down the panel resets, as if the power had been cut off.
Any advice on what could be causing this problem and whether there is a simple repair I could try. It has been getting gradually worse over the last few months and now the oven is virtually unusable.
Thanks in advance, James
