Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   gas range fault F 10 (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/124636-gas-range-fault-f-10-a.html)
ddlong 09-13-2010 10:32 AM
When finished using oven and the timer, a short while later the"beeping starts" and I get fault F 10. What is causing this? What part is needed? I tried turning off the breaker for awhile and even pushed "reset" but problem still exists.
Joe / APP Team 09-13-2010 01:44 PM
Quote:
DD,
The F10 code on your unit indicates a bad oven temperature sensor.
Part number: AP3969435
Did this start occurring after a self clean cycle ?
Did you notice if you had any overheating, cooking problems ?
have you got tools and a meter to access and check the resistance of the temp. probe ?
:cool: :cool: :cool:
