Here are your parts includes a wiring diagram
Replacement parts for FRIGIDAIRE FEF352FSA Frigidaire/electric Range | AppliancePartsPros.comUnplug the unit, remove the bake element and measure it with a meter.
Usually around 20 ohms.
It is a good idea to clip something (clothes pin etc.) onto the element wires when they are in the oven so they do not disappear into the back of the oven.
