Discuss
oven door won't unlock
 in
On our Amana Gas Range #ARGS7650 we tried the self-cleaning feature and now the oven door will not unlock. Related
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven door won't unlock
  #1 (permalink)
Old 09-24-2008, 06:03 PM
Junior Member
drew11201 is on a distinguished road
Default oven door won't unlock
Model Number: ARGS7650   Brand: Amana   Age: 5 - 10 years
Related Models
Amana ARGS7650CC RANGE- S/C S/I GAS
Amana ARGS7650E RANGE- S/C S/I GAS
Amana ARGS7650LL RANGE- S/C S/I GAS
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 09-24-2008, 06:55 PM
Member
Zanshin is on a distinguished road
Default
Most likely, the high temp from the clean cycle (over 900 degrees on some models) has deformed the small microswitch contacts on the door latch assembly so it doesnt know what position it is stuck in. You will need to get to the door latch catch or rod , release it and repair the fault. Most of the time you can access the latch assy from behind the grill or under the smooth top if this is one..
  #3 (permalink)
Old 09-25-2008, 06:33 AM
Junior Member
Default
After checking out some other sites I found this suggestion that worked: turn the circuit breaker off for 5 minutes, turn it back on, start the self-clean cycle, then interrupt it. The oven door unlocked.
  #4 (permalink)
Old 09-25-2008, 11:02 AM
Junior Member
larrym1112 is on a distinguished road
Default
Glad you found the answer for your oven. I have the same problem and posted yesterday. No replies. Any other cites that might help me. Tappan oven more than 10 years old. Thanks. Larrym1112
  #5 (permalink)
Old 01-20-2012, 12:45 PM
Junior Member
crista67 is on a distinguished road
Smile a solution that worked for me
I have an older (2000 model - ARGS7650WW) Amana gas oven/range. The door latch got stuck between locked & unlocked when I tried to clean it and made an annoying beeping noise about every 30 seconds (until I hit cancel) and prevented us from using the unit. We shut off power to the stove for about 30 minutes (5 would probably work). When it came back on, the LOCK light was still on in the display, but I opened the door, pushed in the button to fool it into thinking the door was shut and the mechanical lock starting trying to move. I gently pushed it along into the unlocked position and it the light went off. I was able to successfully use the oven. Of course I'm not going to try using the self-clean cycle any time soon! Hope this helps someone else!
  #6 (permalink)
Old 03-08-2012, 02:41 PM
Junior Member
Rich510 is on a distinguished road
Default Bosch oven
Door is locked and will not unlock
  #7 (permalink)
Old 03-08-2012, 02:53 PM
Junior Member
Default What have you tried?
Quote:
Rich - try unplugging oven for a while (see what worked for me, above). Does that work for your oven? Is it the same brand as mine?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Door Will Not Unlock koolio62 Oven Repair (including Ranges and Cooktops) 0 12-13-2009 07:49 AM
Oven Door will not unlock dshefley Oven Repair (including Ranges and Cooktops) 7 08-02-2009 07:33 AM
Oven Door Won't Unlock BUDDY76 Oven Repair (including Ranges and Cooktops) 4 04-18-2008 10:22 AM
help my oven door will not unlock!! mmtucker Oven Repair (including Ranges and Cooktops) 1 01-03-2008 07:45 PM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 10:40 AM
