Help! My ignitors click continuously. I have tried unplugging each switch at the knobs, still clicks. Disconnected leeds at ignition module, still clicks. Checked votage and ground, checked good. I have a question as to what the voltage shoud be comming from the transformer that feeds the ign. module. If I try to check it, my meter (fluke) goes off on saftey. How can I verify that the module is bad or the transformer. The ign. module is a Harper-Wyman 6526 and is $142.00. Thanks!!!!
