| » broiler and oven wont light |
Model Number: fgb24l2asa Brand: Frigidaire Age: 5 - 10 years
my wall oven - the ignitor works fine; glows red hot, but the gas never lights the burner (which never comes on); there is no smell of gas, so i'm guessing the gas valve does not open; what parts do i need to buy?
Quote:
You most likely need a new igniter Part number: AP2129143 That's the most common resolution for your complaint. Just because it glows does not mean it is working properly. You would need a clamp on ammeter and it should draw a minimum of 3.2 amps when it's glowing. Also, the igniter should glow "white Hot", not red or orange, you should be barely able to look at it. You may want to order the igniter, and replace it, if you don't have access to a meter. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Did you get it diagnosed ? Repaired ?
__________________
| Display Modes | |
| Oven/broiler will not light | may556 | Oven Repair (including Ranges and Cooktops) | 0 | 05-02-2010 12:36 PM |
| LP oven and broiler wont light | docwatson99 | Oven Repair (including Ranges and Cooktops) | 0 | 03-01-2010 06:53 PM |
| GE Gas Stove broiler works but oven wont light | dunndec | Oven Repair (including Ranges and Cooktops) | 1 | 01-28-2009 06:37 AM |
| Oven wont light, broiler will, eventually | Lenty98 | Oven Repair (including Ranges and Cooktops) | 1 | 12-06-2008 08:02 AM |
| oven/broiler won't light | mrides | Oven Repair (including Ranges and Cooktops) | 1 | 07-09-2008 10:57 AM |
