| » Gas Broiler |
Model Number: ARG7600WW Brand: Amana Age: More than 10 years
Gas broiler will not ignite. I replaced the bake igniter last year no problem. Is there an way to see if it is the igniter or more involved? The igniter does NOT glow red.
Quote:
Gerry, You can visually look at the igniter, for cracks(white spots on the gray area is a good indication of a crack), or broken igniter end(gray area). Part number: AP2934763 If you have a multi meter, you can check for 120 AC volts on the wires to the igniter, from the control, when you program a broil selection. If you have voltage on the wires, you have a bad igniter, no voltage would indicate a broken wire or a bad control (clock). ***BE CAREFUL if you decide to run a voltage check*** Let us know what you find,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| broiler | zebdooley | Oven Repair (including Ranges and Cooktops) | 0 | 08-30-2010 02:34 PM |
| Broiler help | cptviggi | Oven Repair (including Ranges and Cooktops) | 1 | 06-27-2010 10:25 AM |
| gas broiler | griffen | Oven Repair (including Ranges and Cooktops) | 1 | 01-29-2010 12:26 PM |
| My broiler won't work | nhoerr | Oven Repair (including Ranges and Cooktops) | 0 | 08-06-2009 07:56 PM |
| broiler help | lblack5415 | Oven Repair (including Ranges and Cooktops) | 1 | 12-31-2008 11:34 PM |
