| » wall oven |
Model Number: rb260pxbq0 Brand: Whirlpool Age: More than 10 years
my electronic display shows the time and allows me to turn the oven on but neither element heats up in bake or broil mode. I opened it up, all the wiring looks intact, I can't find any fuses. Do I need to replace the electronic control panel/
Is this a single or double oven? The wiring diagram has both.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
Ok, I looked at the wiring diagram.....and I don't think it's your control board.
Lets see if we can reset your unit, go to your breaker box throw the breaker all the way off and wait a few seconds then turn it back on. Try the oven. Let me know what it does. Nat
__________________
I switched the breaker off and waited a couple minutes and it is still doing the same thing after I switched it back on. By the way thank you for responding to my question
check the Volts at the breaker make sure it's getting 220V, you may also need to also pull the oven and check the voltage there. If getting the correct voltage then I could be wrong and it be the control board.
nat
__________________
The problem started directly after using the self cleaning mode. There is a switch directly on top of the oven box that interacts somehow with the self cleaning door lock. Could this be where a problem of this type could occur?
Very possible there have been several issues with using self clean and the door latches.
__________________
| Display Modes | |
| Jenn Air Wall Electric Wall Oven | WILLIAM SHIVER | Oven Repair (including Ranges and Cooktops) | 3 | 05-20-2009 12:56 AM |
| What size oven do I need to buy to replace a 70's hotpoint wall oven? | buckeye33 | Oven Repair (including Ranges and Cooktops) | 1 | 04-28-2009 08:42 AM |
| kitchen aid wall oven shuts off periodically when cooking with the upper oven? | eddevlin | Oven Repair (including Ranges and Cooktops) | 6 | 03-15-2009 01:55 PM |
| oven seal parts for gaffers and sattler wall oven | elka | Oven Repair (including Ranges and Cooktops) | 1 | 11-07-2008 02:38 PM |
| Whirlpool Double Wall Oven - Top Oven Not Working | bigguy | Oven Repair (including Ranges and Cooktops) | 6 | 09-18-2008 09:03 AM |
