THE ELECTRONIC RANGE CONTROL FOR MY GE BUILT-IN GAS OVEN NEEDS TO BE REPLACED. THEY HAVE MODIFIED THE ORIGINAL PART AND HAVE REPLACED IT WITH PART #WB27T10327. THE NEW PLUG IN HAS A WHITE WIRE (SAYS CONTINUITY TEST ON IT), THEN A SPACE, THEN ANOTHER WHITE WIRE, A YELLOW WIRE, AN ORANGE WIRE AND A BLUE WIRE. PLEASE IDENTIFY THE HARNESS WIRES TO WHERE THEY GO ON THE OLD CONTROLS; i.e. OVEN SENSOR AND SO FORTH.
IT WOULD BE HELPFUL WHEN PACKING THIS PART IN FUTURE TO IDENTIFY WIRES. PERHAPS IT WAS SUPPOSED TO BE IN THE PACK AND WAS OMITTED. ALSO, WE HAVE NO BLUE WIRE. AM I CORRECT IN ASSUMING THAT THIS WIRE IS FOR A SELF CLEANING FEATURE? THIS IS NOT A FEATURE ON THIS OVEN.
