Discuss
Wall oven loses program
 in
This wall oven will allow you to select a bake function and enter the temperature and the program is accepted
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wall oven loses program
  #1 (permalink)
Old 08-31-2010, 10:23 AM
Junior Member
Rayken is on a distinguished road
Default Wall oven loses program
Model Number: cps130b   Brand: Dacor   Age: More than 10 years
This wall oven will allow you to select a bake function and enter the temperature and the program is accepted and heating commences. Then the program will drop out and revert to the correct time of day. There is no beep as would occur if the cancel pad was shorting. What it does mimic is the situtation when you select a bake function but fail to enter a temperature. After a short period the clock reverts to the time of day.
I think the clock is at fault but am not sure.
Ads By Google
Related Models
Whirlpool CPT08D1A1
Whirlpool CPT08DA1A
Whirlpool CPT18C2A1
Crosley CR1100K Mwave - Cntrtp / Stand Alone
Crosley CR1100KG Mwave - Cntrtp / Stand Alone
Crosley CR1100KW Mwave - Cntrtp / Stand Alone
Amana CR14 Misc / Accessory
Amana CR14L Misc / Accessory
Crosley CR151K Mwave - Cntrtp / Stand Alone
Crosley CR151KWH Mwave - Cntrtp / Stand Alone
Crosley CR151WH Mwave - Cntrtp / Stand Alone
Crosley CR153K Mwave - Cntrtp / Stand Alone
Crosley CR154K Mwave - Cntrtp / Stand Alone
Crosley CR154KWH Mwave - Cntrtp / Stand Alone
Whirlpool CR18PKXRS00 Refrigerator
Whirlpool CR18PKXRS01 Refrigerator
Jenn-Air CR220B Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220B-C Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220W Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220W-C Surf Cont Panel Unit - Ddft Ele
Thermador CR30
Frigidaire CR302VP2D03 Frg(v1) / Gas Range
Frigidaire CR302VP2W03 Frg(v2) / Gas Range
Thermador CR30W
Thermador CR36
Thermador CR36W
Crosley CR4100 Mwave - Cntrtp / Stand Alone
Crosley CR4200 Mwave - Cntrtp / Stand Alone
Crosley CR4614K Mwave - Cntrtp / Stand Alone
Crosley CR4614KWH Mwave - Cntrtp / Stand Alone
Crosley CR464B Mwave - Cntrtp / Stand Alone
Magic Chef CRB21EA-3A Ref - Top Mount
Magic Chef CRB21EN-3A Ref - Top Mount
Magic Chef CRB21EY-3A Ref - Top Mount
Magic Chef CRB22EA-3AI Ref - Top Mount/ I&W
Magic Chef CRB22EN-3AI Ref - Top Mount/ I&W
Magic Chef CRB22EY-3AI Ref - Top Mount/ I&W
Amana CRC10T Commercial Microwaves
Amana CRC10T2 Commercial Microwaves
Amana CRC12T Commercial Microwaves
Amana CRC12T2 Commercial Microwaves
Amana CRC18T2 Commercial Microwaves
Amana CRC18T2OG Commercial Microwaves
Amana CRC18T2OG2  Commercial Microwaves
Amana CRC18T2SD Commercial Microwaves
Amana CRC21T2 Commercial Microwaves
Amana CRC21T2RL Commercial Microwaves
Amana CRC21T2RL2  Commercial Microwaves
Magic Chef CRC22EA-3AW Ref - SXS/I&W
Magic Chef CRC22EN-3AW Ref - SXS/I&W
Magic Chef CRC22EY-3AW Ref - SXS/I&W
Magic Chef CRC24EA-3AI Ref - SXS/I&W
Magic Chef CRC24EN-3AI Ref - SXS/I&W
Magic Chef CRC24EY-3AI Ref - SXS/I&W
Amana CRC510T2 Commercial Microwaves
Amana CRC514D Commercial Microwaves
Amana CRC514T2 Commercial Microwaves
Amana CRC518D Commercial Microwaves
Amana CRC518T2 Commercial Microwaves
Amana CRC8 Commercial Microwaves
Amana CRCR-7 Mwave - Mounted Over Range/wo
Amana CRCR8 Walloven - Std Mwave Ele
Magic Chef CRD22AY-3A Ref - Sxs
Magic Chef CRD22EA-3A Ref - Sxs
Magic Chef CRD22EN-3A Ref - Sxs
Magic Chef CRD22EY-3A Ref - Sxs
Maytag CRE0305ACW Range - F/s Std Ele
Maytag CRE0655ACW Range - S/c F/s Ele
Maytag CRE0775ACW Range - S/c F/s Ele
Amana CRE14 Misc / Accessory
Maytag CRE200 Range - F/s Std Ele
Maytag CRE200B Range - F/s Std Ele
Maytag CRE300 Range - F/s Std Ele
Maytag CRE300B Range - F/s Std Ele
Maytag CRE305 Range - F/s Std Ele
Maytag CRE350 Range - F/s Std Ele
Maytag CRE350B Range - F/s Std Ele
Maytag CRE355 Range - F/s Std Ele
Maytag CRE383 Range - F/s Std Ele
Maytag CRE400 Range - F/s Std Ele
Maytag CRE400B Range - F/s Std Ele
Maytag CRE500 Range - F/s Std Ele
Maytag CRE500B Range - F/s Std Ele
Maytag CRE600 Range - F/s Std Ele
Maytag CRE600B Range - F/s Std Ele
Maytag CRE650 Range - F/s Std Ele
Maytag CRE655 Range - S/c F/s Ele
Maytag CRE682 Range - S/c F/s Ele
Maytag CRE682B Range - S/c F/s Ele
Maytag CRE683 Range - S/c F/s Ele
Maytag CRE700 Range - S/c F/s Ele
Maytag CRE750 Range - S/c F/s Ele
Maytag CRE7500ACL Range - F/s Std Ele
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Oven Takes Forever to Preheat then Loses Temp. spires_c Oven Repair (including Ranges and Cooktops) 0 07-08-2010 08:56 PM
GE Profile Model P2S975SEM2SS Slide-In Range Temporarily Loses Power When Oven Used Bilgemaster Oven Repair (including Ranges and Cooktops) 0 10-25-2009 06:18 AM
Program Oven Capacity Size chokes7 Oven Repair (including Ranges and Cooktops) 1 08-17-2009 11:32 AM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
Oven loses heat pottersclay48 Oven Repair (including Ranges and Cooktops) 1 11-30-2008 07:00 AM
