My 5 burner cooktop serial #96090122 is converted to propane. All burner ignitors work but the right front XLO will not light. The burner cap is set properly, the jet orifice is clean and the knobs are not cracked. I do not hear or smell propane on the burner but the ignitor is working. I purchased a new potentiometer BSH189819 from Appliance Parts Pros.com and installed it. The burner worked fine for 4 or 5 tries. Then while cooking, I went to adjust the flame ever so slightly and it went out completely and I have not been able to re-light it since but the ignitor still works. What would be my next step? Thanks, Dave
