I have consulted a number of sources regarding a replacement broiler element for this oven. All responses are that the model is not in database. OK, this is an old unit...although not an antique as one rep called it...I just need a recommendation on a part that can substitute! This seems to be a standard part...perhaps, there is a universal broiler element with the same terminal connections that I can just plug into the oven. Can you assist? :confused:
