dmulder
#1 Posted : Saturday, September 13, 2008 7:43:20 PM(UTC)
dmulder
We have a free-standing kenmore gas range that is less than 18 months old. Tonight when we turned it in to preheat the oven to 400 after it beeped that it was preheated it turned off and gave me an error code F30. I turned the oven off and turned it back on a few minutes later. It seemed to run fine for about 10 or 15 minutes then all of a sudden turned off again and gave us an error code F10 and just kept beeping. Eventually we were able to get that stopped and left the oven off for 10 minutes or longer. I then turned it back on but only to 375. It seems to be working but there isn't much heat coming out of the upper vent. I am having trouble locating my range model on any of the websites and can't find the error codes. Can anyone help?
libertyappl
#2 Posted : Saturday, September 13, 2008 7:49:20 PM(UTC)
libertyappl
Your model is actually made by Frigidaire, Kenmore doesn't make anything.
I haaven't seen an F10 or F30 code, but an F1 code is the sensor and F3 is the ERC(control board)
You can pull up a parts break down on the www3 sears website.
I would start by checking the connections on the control board.
Nat
debbiesue
#3 Posted : Monday, September 15, 2008 9:30:05 AM(UTC)
debbiesue
i just installed in entire new control panel and am getting an f3 error code when i turn the oven or broiler on?
libertyappl
#4 Posted : Monday, September 15, 2008 9:38:35 AM(UTC)
libertyappl
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nat
Jenn-air Gas Range Error codes (Oven Repair (including Ranges and Cooktops))
by uncledave11 3/29/2018 11:48:39 AM(UTC)
Whirlpool gas range error codes (Oven Repair (including Ranges and Cooktops))
by Dan Wilshire 7/8/2009 9:05:41 AM(UTC)
