Discuss
Jenn-Air Wiring
 in
I inherited the job of fixing an older Jenn-Air model S160 range that has numerous wiring problems--I found
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Wiring
  #1 (permalink)
Old 09-20-2007, 09:39 AM
ezra710 ezra710 is offline
Junior Member
ezra710 is on a distinguished road
Default Jenn-Air Wiring
Model Number: S160   Brand: Jenn-Air   Age: More than 10 years
I inherited the job of fixing an older Jenn-Air model S160 range that has numerous wiring problems--I found some exposed wiring and burned female contacts, which are all easy to fix, but it looks like someone rewired the burner element to be a 3-wire system, while the range wiring is all 4-wire (and some of it looks like it's been changed). There is no wiring diagram, so I do not know the correct wiring for either the burner or the range inself. Help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-air 88370 Schematics claude_123 Oven Repair (including Ranges and Cooktops) 3 10-19-2008 09:40 AM
Please Help! Jenn Aire Clock Display abbymac Oven Repair (including Ranges and Cooktops) 2 11-01-2007 11:41 AM
wiring ? opie Dryer Repair 1 09-11-2007 04:16 AM
Jenn-Air Wiring Repair Rescue JenSed Oven Repair (including Ranges and Cooktops) 5 08-21-2007 11:53 AM
water valve wiring hotpoint/ge Cuch Washer Repair 2 07-24-2007 06:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
