I have a Jen-aire Model S105 that I need a wiring diagram for.I have the original one but it is unreadable now. I just bought a bake element from appliance parts pros the other day and it will be here tomorrow. The reason is that some food spilled over onto the bake element and shorted out bake element to bottom of stove causing it to "burst". The last time this happened it also took out the selector switch which was not available last time and is still not available to day. What I did last time was go to an aplliance parts house got a simular switch took it apart and repaired old switch with parts from the new one. Im not 100% sure the switch is bad, it ohm's out fine but thats with no load, I just want to be ready just in case. I need this stove to work for about 1 month till I get my new stove. My stove has to be a electric 30" slide in with downdraft and only jenn-aire seems to be the model I can use,not sure why it takes 1 month to get one though. I need the diagram so I can wire in a new switch or rewire to work on another circuit in case it is actual bad. Anyway Thanks Craig
I got my bake element today installed it and all is ok at this time, switch still works. Thanks
