I have 4 of these in my house. (2 upstairs kitchen, 2 downstairs kitchen.)
For some reason, the 2 in the basement had their gas inlet valve stop working within 6 months. Any who, I changed the gas valve and they started working.
But one of the oven is still giving problems. Its broiler now works fine, but the bake function is acting kind of funky. On a cold start, the oven has NO problems igniting. But after it gets in the 200-300 degree range, it starts failing to ignite. Thus, it sometimes preheats, and sometimes doesnt. (Regardless, the oven will begin cooling after it fails to cycle back on). Turning oven off and on will also fail to cycle the oven. So once it gets to 200-300, it will fail untill you let the oven cool off and wait an hour or so..
Also, accoriding to the diagram on sears website under "oven parts", the bake heating element consists of 2 items.
Part Number: 4454047 and 4454048.which one would i order? Both? How can i tell if i need both?
where can i find instructions on replacing it?
thanks a lot for any help!
