HI I have a F30 Err code showing up. My question is does this error code incorporate two errors the first one being the oven temp sensor(F3) and the second being an EOC or clock(F0)? On the touch pad all three conv buttons, the pre heat, broil, and bake buttons cause the error to come on. The clock, timer, bake and start time, and keep warm buttons are not functioning. Could these last set of buttons be due to the oven sensor issue or does it mean the clock part is bad? Thanks Greg
