Modern Maid Double Gas Oven
Brand: Modern Maid Age: More than 10 years
Hello,
I moved into a home and it has a Modern Maid Gas Double Oven installed in the Cabinet. The broiler works, but neither of the bottom ovens will light. Both pilots are lit and do not fluctuate when the oven is turned on. I have tried to light it using a small lighter, but that will not work either. I would love help diagnosing and fixing the problem, but I cannot find the Model number. I have looked everywhere I can think of, without removing it from the cabinet, to no avail. I don't know if this helps but the oven trays say Infra Ray on it and it has the Automatic Cook' N Hold feature. It looks pretty old.
Any help is appreciated,
Thanks,
Kevin
Ads By Google
