Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Maytag man quit his hobbies (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/115703-maytag-man-quit-his-hobbies.html)
poppasquirrel 08-18-2010 03:23 PM
The Maytag tag line must have gotten retired, our stuff is failing us (Oh, well)
Our faithful range has done great things for us since being married and it finally won't light the oven-- even for daddy-o.
Model# MGR5780BDW
The pucks on the range light, the broiler broils, but the oven will not start.
The igniter gets bright orange and will remain as such without triggering the valve to loose the hounds er, the gas.
A forum post suggested an ammeter test, but I've only the probe-style and not the wrap-around variety.
Set oven to 350 with unit plugged into outlet, tested across poles on bi-metal valve terminals and got a reading in the .01--.03 range. Likely the reading and information I gave is amusing at best (I did a no-no?).
Should I jump for the new ammeter THEN retest the igniter?
Maybe go hog wild and buy an igniter?
Or (WAHOO!) pitch the thing and get a non-Maytag range?
Your input is essential, ladies and gentlemen.
God bless you,
Poppa Squirrel
Gene 08-18-2010 06:57 PM
Most likely the problem is a bad (weak) igniter. If you would like to measure the current drawn by the igniter, you should wire an amp meter in series with the igniter and set it on 0-20 amps scale. You also can use a clamp on amp meter which does not need to be wired in but such meter is much more expensive.
I would just order the new igniter and install it to see if it will fix the problem. If not, you can return it (only if it's ordered from Appliance Parts Pros).
- The oven igniter Part number: AP4096256
Here are the breakdown diagrams and Replacement parts for MAYTAG MGR5780BDW Range - S/c F/s Gas | AppliancePartsPros.com
