liuguang
#1 Posted : Wednesday, September 3, 2008 8:07:24 AM(UTC)
liuguang
I recently replaced oven control module (part # WB12K5005) for GE Oven/Microwave combo (model # JKP65WOP3WG). It was working OK first. Now everytime when I preheat the oven to 350C it resets itself - all display turned on - then followed by PF error message.
I have reset the clock, reset the power from basement distribution panel. It won't fix the problem. Does this indicate a bad control module?
abadfish66
#2 Posted : Wednesday, September 3, 2008 8:18:57 AM(UTC)
abadfish66
Are you setting if for 350 Celsius or 350 Farenheit?, big difference.
liuguang
#3 Posted : Wednesday, September 3, 2008 10:50:22 AM(UTC)
liuguang
It's Celsius always. The starting temp is at 150C, I increase temp reading to 350C. I don't even know how
to change unit from Celsius to Farenheit. Thanks for the comments.
abadfish66
#4 Posted : Wednesday, September 3, 2008 11:30:05 AM(UTC)
abadfish66
I think that is your problem. Press and hold bake and broil at the same time until the display changes to SF. After you see SF, press broil pad it should come up C press broil again it should say F after that press start. Now program to bake at 350 and see what happens
GE oven control module (Oven Repair (including Ranges and Cooktops))
by droper 10/14/2007 4:45:53 PM(UTC)
