| » red indicator light exploded, Whirlpool Electric Cooktop |
Model Number: rcs3004rs00 Brand: Whirlpool Age: 1 - 5 years
Like a firecracker...the red indicator light on our Whirlpool Electric Cooktop (model # rcs3004rs00) just exploded! LITERALLY!
Anyone out there experienced such an issue? Suggestions? I went ahead & ordered the part, but I'm wondering if maybe I ought to do some troubleshooting prior to installing the new indicator light, so I don't explode it too! I'm pretty handy with a mulitmeter & Dad's an electrician. Thanks in-advance for your insight. -Bay Area John Ads By Google Related Models |
Quote:
Based on the wiring diagram, I think that is a 240 VAC indicator light. (no switch circuitry, in diagram). Do all the burners work ? You may want to visually check the burner receptacles for damage and the switches and wiring as well, before you install the new light.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Joe M.,
Thanks for your response to my question about the exploding indicator light. I will investigate, like you suggested...before replacing the part with a new one. I wonder what the easiest way to replace it is...maybe remove the cooktop somehow????...I don't know...never done it before. Thanks! Bay Area John |
Quote:
Attached the service manual for you to review and use as you need to. It covers several models, including yours, and should get you through the repair pretty easy. Good luck http://servicematters.com/tech_ref/JA/ja_main.htm
__________________
John!
This just happened to my wife and I while cooking dinner. It looks like it tripped the breaker. And I'm scared to turn it back on. Do you remember what it took to fix your stove? Was it ruined or did you just have to replace the little bulb? Thanks, Todd |
Todd, If the unit shorted and tripped the breaker, this would indicate a short to ground. You'll need to turn the power off, raise the cooktop and check the wiring at the switches and indicator lights to see if you had moisture or water in the wiring,and switches from a "spill over". All these circuits are 220/240 VAC, so be careful, and make sure the power is "OFF" before you start.
__________________
| Display Modes | |
| Help! Indicator Light Elec. Cooktop | musicew | Oven Repair (including Ranges and Cooktops) | 0 | 01-05-2010 12:09 PM |
| GE Electric Cooktop - Hot surface light will not shut off | silverms | Oven Repair (including Ranges and Cooktops) | 0 | 11-12-2009 12:33 PM |
| GE Touch Control Radiant Cooktop Hot Indicator light stays on | DHB | Oven Repair (including Ranges and Cooktops) | 0 | 03-19-2008 06:30 PM |
| radiant cooktop unit-on indicator light stays on | muggy442 | Oven Repair (including Ranges and Cooktops) | 0 | 02-15-2008 03:01 PM |
| whirlpool electric coil cooktop | jaffej | Oven Repair (including Ranges and Cooktops) | 0 | 07-25-2007 09:06 AM |
