| » oven igniter |
Model Number: mgr5875qds Brand: Maytag Age: 1 - 5 years
oven has quit working, the the clean cycle will work. i have taken the igniter out plug it into 110 volts it glows bright red almost white
can the igniter still be bad?? Related Models |
Set the control to bake, check the schematic, and check the bake output wire from the control, if no voltage, you probably have a bad control module. Before replacing, check the resistance of the oven sensor, if way off it's room temperature resistance( should be around 1Kohm) replace it. Click on your
Model # to get the part #.
__________________
| Display Modes | |
| how to replace igniter on thermador gas grill | cosomactoo | Oven Repair (including Ranges and Cooktops) | 1 | 09-19-2007 08:24 PM |
| oven igniter does't heat up | poplin,earnest | Oven Repair (including Ranges and Cooktops) | 1 | 09-19-2007 08:12 PM |
| Replaced the igniter and there is still no heat in my oven??!! | Ruben | Oven Repair (including Ranges and Cooktops) | 1 | 08-21-2007 11:44 AM |
| Igniter glows but no flame. | zab | Dryer Repair | 1 | 08-06-2007 07:55 PM |
