| » Still Getting an F3 Code after heat sensor was replaced |
Model Number: MES5770AAW Brand: Maytag Age: 5 - 10 years
I was told an F3 error code was a sign for a faulty heat sensor. I replaced this and it worked once.. then reverted back to F3 code whenever we try to heat the oven above 200-250. The one time i did get it to work when it was cooling the I noticed the fan was going on and off erratically. Any thoughts / suggestions on what to try next?
Quote:
Are you sure all the connections are proper and tight ? I fear you may have a control problem, if you're sure about the wiring. To check your new sensor: with a meter the sensor should read 1,050 to 1,100 ohms at room temperature(78 dgrs) At 210 dgrs. (boiling water) the resistance should increase to 1,350 to 1,400 ohms. The erratic cooling fan, and the F3 code(still), leads me to believe its a loose wire connection on the sensor harness. Once you've re checked and varified the harness and sensor resistance, you would need a range control board(clock). You should check those resistance readings at the sensor harness, where it connects to the range control board, for a more complete and accurate reading,diagnosis. (see attached ) Part number: AP4396964
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Replaced Glow Igniter, Sensor and coils yet no heat in dryer | Camann | Dryer Repair | 0 | 12-17-2009 08:19 AM |
| F3 code remains after sensor is replaced | timp87 | Oven Repair (including Ranges and Cooktops) | 2 | 01-27-2009 05:32 AM |
| Replaced Element and Sensor Still Error Now What???? | garylrodgers | Oven Repair (including Ranges and Cooktops) | 12 | 01-01-2009 07:35 AM |
| Replaced Sensor Still Getting F3 Error | justme123 | Oven Repair (including Ranges and Cooktops) | 3 | 09-21-2008 08:56 AM |
| GE F3 sensor replaced but still get error F3 | dpmath | Oven Repair (including Ranges and Cooktops) | 1 | 04-02-2008 05:45 AM |
